14 years agoNCO phase drift
Hello, I have an NCO generating a 60 Hz sine output. input clk = 10 khz phase accumulator precision = 32 bits angular resolution = 32 bits magnitude precision = 10 bits phase incr...
14 years agoTo allow PLL locking in "finite" time, you should allow at least 0.5 or 1 Hz frequency adjustment, I think. The PLL filter has to be designed for a respective lock range in case of an XOR or similar phase detector without frequency comparison
I'm using mains frequency PLLs mostly with "hybrid" (ADC based) analog phase detectors, because typical power electronic related designs involve mains voltage measurement channels anyway.
