14 years ago
NCO help...
Hi i'm trying to test a fixed point filter on a FPGA board, my filter has an input of 16 bit, but the maximum value it can take without saturation is 1023 which is 11 bits. so far the only signal i've been using to is the NCO megafunction. when i set the NCO to have a magnitude of 16 bits i get severe distortion and loss of precision, i cant change the NCO to have a smaller number of bits or i get a bit mismatch, and i cant reduce the number of bits of the filter because i get distortion and loss of precision again. i'm using simulink and fixed point advisor in simulink to design this filter....
Can anyone please help..? not sure if there is another way to test the filter with a more dynamic signal. or if anyone is familiar with simulink how i can optimize my design.
    I am not sure about simulink generated code. I use DSPBuilder which is based on simulink blocks but specific blocks for target devices (altera or xilinx). DSPBuilder works but simulink is not used in the industry to generate code since there is DSPBuilder ...etc.
    Now the question is why the order of blocks is not right. The second issue is that of NCO which was first title posted If you suspect NCO then you can rule that out by either rescaling your FIR coeffs or you can use random data or even just one impulse (1,0,0,0..etc) at required level, pass it through model then through hardware and see the difference. At the moment you will be checking model Versus hardware so if the model is wrong functionally it will not be relevant, you only want to check model against implementation. Once done then you start to question if model is correct. You are saying that simulation works ?? how could it be if the blocks are in the wrong order... I think you need to explain your setup and results further.
    No the blocks are in the right order, if you look at the link you see they are the same as the simulink model i posted. at this point i'm looking to do whatever it takes to make this work. i didn't know DSPbuilder was the industry standard. maybe i'll have better luck with that. how would i get this code into DSPbuilder, maybe then we'll be easier for us to be on the same page.
    N = 99; [H0,H1,G0,G1] = firpr2chfb(N,.45);
    % Analysis filters (decimators). Hlp = mfilt.firdecim(2,H0); Hhp = mfilt.firdecim(2,H1); % Synthesis filters (interpolators). Glp = mfilt.firinterp(2,G0); Ghp = mfilt.firinterp(2,G1);
    --- Quote Start ---
    --- Quote End ---
    No that is not right. The link diagran puts H0 filter followed by down 2,
    your model puts rate transition then LOwPassFilter.
    Am I looking at the wrong link. Moreover it defies theory to put rate transition before decimating filter.
    For DSPBuilder you will choose blocks of decimator/interpolator and connect them. You choose your coeffs as well which might well be same as your or scaled for unity gain. The rate conversion is implied in the filter itself. Once done then you run DSPBuilder to generate code and testbench.
    My apologies, the matlab function mfilt.firdecim and mfilt.firinterp already down sample and up sample. I put the transition blocks there because I want sure if it was necessary.
    Fair enough. But do you use the functions to generate the code or the simulink blocks. Put in other words, Does the blocks named LOwPassFilter ...etc do the rate transitions. In that case you don't need these transitions duplicated. It is a habit of diagrams makers to mislead when describing functionality !
    Yeah there is a realizemdl function that generates them into simulink blocks, then from simulink i use the fixed point advisor tool to convert from floating point to fixed point, and then i use the HDL coder to generate HDL code. yes i do agree thats y ive been so lost i feel like ive been mislead and wasted a lot of time.
