14 years agoNCO help...
Hi i'm trying to test a fixed point filter on a FPGA board, my filter has an input of 16 bit, but the maximum value it can take without saturation is 1023 which is 11 bits. so far the only signal i'v...
14 years agoFair enough. But do you use the functions to generate the code or the simulink blocks. Put in other words, Does the blocks named LOwPassFilter ...etc do the rate transitions. In that case you don't need these transitions duplicated. It is a habit of diagrams makers to mislead when describing functionality !
