13 years ago
My code doesnt complete synthesis
Hello i am trying to implement this code in a cyclone IV. I can't understand why it never finishes the synthesis process, i do understand that it's a lot of routing to be done but it can't even finish SYNTHESIS. And this code does work at the MODELSIM, it does exactly what i expect it to do.
The processing element which i am instantiating is an 8 bits XOR.
entity dicionario is
Port ( sys_clk : in STD_LOGIC;
sys_rst : in STD_LOGIC;
word : in STD_LOGIC_VECTOR(7 downto 0);
valid_word : in STD_LOGIC;
symbol_out : out std_logic_vector(23 downto 0)
end dicionario;
architecture Behavioral of dicionario is
type arr is array(0 to 2047) of std_logic_vector(7 downto 0);
type symbol_arr is array(0 to 255) of std_logic_vector(7 downto 0);
type sm_t is (WAIT_START, COUNT_WORDS, PRIORITY_ENCODER);
-- sinais do dicionario
signal match : std_logic_vector(2047 downto 0);
signal old_match : std_logic_vector(2047 downto 0);
signal search_buff : std_logic_vector(2047 downto 0);
signal lookahead_buff : std_logic_vector(63 downto 0);
signal past_words : std_logic_vector(2047 downto 0);
signal symbol : std_logic_vector(23 downto 0);
signal word_counter : natural range 0 to 2048;
signal done_reg : std_logic;
signal word_reg : std_logic_vector(7 downto 0);
signal symbol_vector : symbol_arr;
signal word_vector : arr;
signal state : sm_t;
signal set_reg : std_logic;
signal info_pack : std_logic_vector ( 31 downto 0);
constant zeroes : std_logic_vector(2047 downto 0) := (others => '0');
constant ones : std_logic_vector(2047 downto 0) := (others => '1');
COMPONENT processing_element
PORT(
sys_clk : IN std_logic;
sys_rst : IN std_logic;
set : IN std_logic;
x : IN std_logic_vector(7 downto 0);
y : IN std_logic_vector(7 downto 0);
match : OUT std_logic
END COMPONENT;
begin
symbol_out <= symbol;
processing_element_for:
for I in 0 to 2047 generate
Inst_processing_element : processing_element PORT MAP(
sys_clk => sys_clk,
sys_rst => sys_rst,
set => set_reg,
x => word,
y => word_vector(2047-i),
match => match(2047-i)
end generate processing_element_for;
process(sys_clk)
begin
if rising_edge(sys_clk) then
if sys_rst = '1' then
set_reg <= '1';
done_reg <= '0';
symbol <= (others => '0');
state <= WAIT_START;
old_match <= ( others => '0');
else
case state is
when WAIT_START =>
if valid_word = '1' then
set_reg <= '0';
if ((match /= zeroes) and (match /= ones)) then
word_counter <= word_counter + 1;
state <= COUNT_WORDS;
end if;
end if;
when COUNT_WORDS =>
end if;
if match = zeroes then
set_reg <= '1';
symbol <= x"00" & std_logic_vector(to_unsigned(word_counter,16));
word_counter <= 0;
else
old_match <= match;
end if;
end case;
end if;
end if;
end process;
-- SHIFT REGISTER
process(sys_clk)
begin
word_reg <= (others => '0');
for i in 0 to 2047 loop
word_vector(i) <= (others => '0');
end loop;
else
word_reg <= word;
word_vector(2047) <= word_reg ;
for i in 0 to 2046 loop
word_vector(2047-i-1) <= word_vector(2047-i);
end loop;
end if;
end if;
end if;
end process;
end Behavioral;
    --- Quote Start ---
    1 hour - come back when it hasnt finished for 1 day.
    --- Quote End ---
    hehe i have had designs that took 2 days to compile but this seems so simple...
    i thought i was doing something very wrong in the RTL design but the simulation works fine and it seems to be correct (it's a Lempel–Ziv Compression algorithm for VLSI based on an article)
    i will try to let it compiling for a while then, tyvm
    --- Quote Start ---
    How long have you left the synthesis before you stopped it?
    --- Quote End ---
    1 hour.
    the code seems pretty simple, as i said it compiles in 5 mins if i change the vector size for 256 bits.
    the project is just this entity, i've waited for 4 hours...
    it compiles in 5 mins if i change the vectors for 512 bits size
    How much time do quartus spent until you finished the compilation process? Maybe simply the quartus doesn´t finish and depending on the project it really takes a lot of time.
    --- Quote Start ---
    What is the error that quartus do during the fitter?
    --- Quote End ---
    There is no error, it just never finishes
