15 years ago
Multiplication by 0,6
Hi i have an input of 8 bits and i need to make a
multiplication by 0,6. I doesn't has to be precise so
i thaught to do :
INPUT * 19 /32
This is not a working code but is displays what i wanna do:
array_amp_to_find(column_counter) <= std_logic_vector (to_unsigned ((to_integer(CAM_DATA)*19/32), 8));
Both input (CAM_DATA) and output (array_amp_to_find) are
std_logic_vectors (7 downto 0).
Q: How to make it work in one cycle? Or first the calculation then take the 8 LSB's?
    --- Quote Start ---
    Yea thaught so. I would be nicer to write a code in one line.
    Thx anyway!
    --- Quote End ---
    Library IEEE;
    	use IEEE.Std_Logic_1164.all;
    	use IEEE.numeric_std.all;
    dn <=  to_integer( unsigned( CAM_DATA )) ;
    Q <=  std_logic_vector( to_unsigned( dn * 16 + dn * 2 +dn  , 13))(12 downto 5) ;
    -- or in 1 line
    Q <=  std_logic_vector( to_unsigned(  to_integer( unsigned(  CAM_DATA )) * 16 +  to_integer( unsigned(  CAM_DATA )) * 2 +  to_integer( unsigned(  CAM_DATA ))  , 13))(12 downto 5) ;
    Thx anyway!
    I believe the calculation takes one clk cycle even if you use the temporary variable result,
    since the last one is a continuous assignment, not clock sensitive.
    The actual VHDL code could be:
    multiply_0_6 : process (clk, CAM_DATA)
    begin
    if (clk'event and clk='1') then
    result <= ("0" & CAM_DATA & "0000") + ("0000" & CAM_DATA & "0") + ("00000" & CAM_DATA)
    end if;
    array_amp_to_find(column_counter) <= result(12 downto 5);
    end process;
    (disclaimer: I'm not a VHDL expert, so I don't know if this is the correct syntax and if my code is actually working as supposed)
    Thx,
    Does someone has an ID how to take the (12 downto 5) in the sametime
    with the calculation ?
    <= (12 dwonto 5) (("0" & CAM_DATA & "0000") + ("0000" & CAM_DATA & "0") + ("00000" & CAM_DATA));
    is not working :)
    Please note that there's no need to perform the actual /32 division. You can simply multiply 19 and discard the 5 LSB.
    Moreover multiplication *19 can be reduced to a three terms addition:
    CAM_DATA*16 + CAM_DATA*2 + CAM_DATA*1
    which is equivalent to:
    where result is std_logic_vector(12 downto 0).
    Then:
    So, neither an actual multiplier is required.
    I think this can be easily synthesized to work in a single cycle.
    (I'm not sure about this VHDL syntax, please check; I'm used with Verilog)
