15 years agoMultiplication by 0,6
Hi i have an input of 8 bits and i need to make a multiplication by 0,6. I doesn't has to be precise so i thaught to do : INPUT * 19 /32 This is not a working code but is displays wh...
15 years agoPlease note that there's no need to perform the actual /32 division. You can simply multiply 19 and discard the 5 LSB.
Moreover multiplication *19 can be reduced to a three terms addition: CAM_DATA*16 + CAM_DATA*2 + CAM_DATA*1 which is equivalent to: result <= ("0" & CAM_DATA & "0000") + ("0000" & CAM_DATA & "0") + ("00000" & CAM_DATA) where result is std_logic_vector(12 downto 0). Then: array_amp_to_find(column_counter) <= result(12 downto 5); So, neither an actual multiplier is required. I think this can be easily synthesized to work in a single cycle. (I'm not sure about this VHDL syntax, please check; I'm used with Verilog) Regards
