16 years agoMultiple instances of VHDL file on one device
Hi everyone I've managed to generate a FIFO using the megafunctions in Quartus. I was wandering if there is an easy way of putting two of these FIFOs onto one device without lots of extra VHDL ...
16 years agoThank you for the quick response.
I've done what you recommended and I've now got two instances of the fifo in a schematic but if I try to run analysis and synthesis it tells me that "the top partition does not contain any logic" I haven't put any wires in because i want the outputs of both fifos to appear on the pins of the FPGA. Are there any more pointers you can give me? Thanks again Dan
