multiple driver error during simulation
Hi
I am doing a project and am stuck in the synthesis part in Quartus. The code was successfully compiled using icarus verilog software.But while compiling the code in Quartus , I get some error messages. The code is as follows with its description: /* Whenever positive edge of switch occurs , I need to take the incoming 8 bits (serial inputs on a single pin) and after that I have to discard all the bits, until the next posedge of switch. These bits are coming from a parallel in serial out register. These bits are stored in a reg called c and i is an integer which keeps the count. */ module test(si,po,clk,switch,flag); input si,clk,switch; output reg [7:0] po; reg [7:0] c,d; output reg flag; reg count; //reg flag; integer j,i; initial i=0; initial flag=0; initial count=0; always@(posedge clk) begin if (flag==1) begin c[i]=si; i=i+1; if(i==8) begin //count<=1; //po<=c; po<=(c[7:4]*10)+c[3:0]; i=0; flag<=0; end end end always@(posedge switch) begin flag<=1; end endmodule The error messges are as follows: Error: Can't elaborate top-level user hierarchy Error (10029): Constant driver at test.v(16) Error (10028): Can't resolve multiple constant drivers for net "flag" at test.v(38) Could anyone help in rectifying the mistake?17 Replies
The counter is used to move the current input bit to the coorect bit index of output. Thats why I say output(count) <= input i.e.:
output(0) <= input bit when count = 0 output(1) <= input bit when count = 1 ...etc. so count must go up at speed of incoming serial bits. - Altera_Forum
Ok well trying out some suggestions, I am here with the final code
module test1(si,po,clk,switch,flag); input si,clk,switch; output reg [7:0] po; reg [7:0] c,d; output reg flag; reg check; reg count; //reg flag; integer j,i; initial i=0; initial flag=0; initial count=0; always@(posedge clk) begin if(switch==0) check=1; if(switch==1 & check==1) begin check<=0; flag<=1; end if (flag==1) begin c[i]=si; i=i+1; ///end if(i==8) begin po<=(c[7:4]*10)+c[3:0]; i=0; flag<=0; end end end endmodule Can someone suggest how to optimise this code . I am using a CPLD board which says it requires 94 macrocells for this code but it has got only 64.:) - Altera_Forum
aside from resource issue, I think you need a bit more thought on the issue of counting. you need to count 0 ~7 and then freeze on zero until next switch edge.
One way is this: if switch = '1' ... count <= 1; elsif flag = '1' then count <= count + 1; end if; flag <= '1' when count > 0 else '0'; - Altera_Forum
The multiplier/ adder is going to take too much resource.
To avoid the multiplier you can use shift and addition for 10 i.e. multiply by 8 using 3 bit shift then multiply by 2 using one bit shift then add products
Thank You Kaz for the help.
I am still short of 13 macrocells and also I would like to extend this code for 16 bits instead of 8 bits. Any concrete solution? - Altera_Forum
I haven't done verilog for ages. I believe your integer (i ) may imply 32 bits in hardware. You only need 3 bits so try constraining that e.g. by using reg.
