15 years agomultiple driver error during simulation
Hi I am doing a project and am stuck in the synthesis part in Quartus. The code was successfully compiled using icarus verilog software.But while compiling the code in Quartus , I get some error...
15 years agoOk well trying out some suggestions, I am here with the final code
module test1(si,po,clk,switch,flag); input si,clk,switch; output reg [7:0] po; reg [7:0] c,d; output reg flag; reg check; reg count; //reg flag; integer j,i; initial i=0; initial flag=0; initial count=0; always@(posedge clk) begin if(switch==0) check=1; if(switch==1 & check==1) begin check<=0; flag<=1; end if (flag==1) begin c[i]=si; i=i+1; ///end if(i==8) begin po<=(c[7:4]*10)+c[3:0]; i=0; flag<=0; end end end endmodule Can someone suggest how to optimise this code . I am using a CPLD board which says it requires 94 macrocells for this code but it has got only 64.:)
