8 years ago
Multiple directories for multiple instances
I am using a 2 PCIe hard IP which differ in settings in the platform designer. When I generate HDL, I see a common folder for both the IP.
The reason being a bug is there in the logic of PCIe which has to be implemented differently for each instance.
How can I generate a separate folder for each IP?
Vijey
    You don't say whether you are using Standard or Pro, but even though a single folder is used for the same IP, there are separate files for the different parameterizations. What is the reason why you want to separate things?
    As mentioned, you could have two .qsys files and add one as a subsystem of the other.
    Hi Vijey,
    Can't you have two Qsys files and connect them together after instantiating in your top file? This way, you will have two different folders for your Qsys and thereby the IPs.
    Hi Lijo,
    Thanks for the reply but I did not understand what you intend to convey.
    I have 2 IP in Qsys with different settings. When I give generate HDL, it generates for the entire system.In the process only one folder is created for 2 instances and they are passing the parameters differently from the top file. Since I have a bug in addressing of IP I have to fix them individually instead of using the same file.
    Any solution to generate two separate folders for the same IP of multiple instances used in the same design?
    Vijey
    Hi Vijey,
    When you generate the IP, a window will pop up asking where to save the IP. You can choose any folder you want. Hope this helps.
    Kind regards,
    Lijo
