8 years agoMultiple directories for multiple instances
Hi, I am using a 2 PCIe hard IP which differ in settings in the platform designer. When I generate HDL, I see a common folder for both the IP. The reason being a bug is there in the logic of PC...
8 years agoYou don't say whether you are using Standard or Pro, but even though a single folder is used for the same IP, there are separate files for the different parameterizations. What is the reason why you want to separate things?
As mentioned, you could have two .qsys files and add one as a subsystem of the other.
