8 years agoMultiple directories for multiple instances
Hi, I am using a 2 PCIe hard IP which differ in settings in the platform designer. When I generate HDL, I see a common folder for both the IP. The reason being a bug is there in the logic of PC...
8 years agoHi Vijey,
When you generate the IP, a window will pop up asking where to save the IP. You can choose any folder you want. Hope this helps. Kind regards, Lijo
