8 years agoMultiple directories for multiple instances
Hi, I am using a 2 PCIe hard IP which differ in settings in the platform designer. When I generate HDL, I see a common folder for both the IP. The reason being a bug is there in the logic of PC...
8 years agoHi Vijey,
Can't you have two Qsys files and connect them together after instantiating in your top file? This way, you will have two different folders for your Qsys and thereby the IPs.
