8 years agoMultiple directories for multiple instances
Hi, I am using a 2 PCIe hard IP which differ in settings in the platform designer. When I generate HDL, I see a common folder for both the IP. The reason being a bug is there in the logic of PC...
8 years agoHi Lijo,
Thanks for the reply but I did not understand what you intend to convey. I have 2 IP in Qsys with different settings. When I give generate HDL, it generates for the entire system.In the process only one folder is created for 2 instances and they are passing the parameters differently from the top file. Since I have a bug in addressing of IP I have to fix them individually instead of using the same file. Any solution to generate two separate folders for the same IP of multiple instances used in the same design? Thanks, Vijey
