12 years agoMulti SD CARD controller
Hi all,
I'm doing a design with 4 SD cards, in sd 4 bits mode at 50MHz in parallel with an embedded Nios on a ARRIA V target. Here are the facts: - By instantiating the sd ip without Nios, communication goes well and we arrive to write fixed pattern on all cards. - By adding the Nios (Nios + RAM + Ethernet), there are 2 cards of 4 arriving to work properly Has anyone ever used multiple SD cards within one design? Are there timing constraints add on the sdc file to use efficiently sd card ? I suspected problem of random delay depending on the quartus routing or fitting, between the sd clock and the 4 bits of data. Thank you for your help5 Replies
How have you constrained this?
Yes, you will have to ensure you clock to out times are appropriate. However, you mention running at 50MHz - I don' think you should have much of a problem in Arria running at that frequency. Are you registering data on and off the FPGA in the I/O cell? Are you happy that, in connecting up your Nios core, you haven't inadvertently incorrectly connected something? Regards, Alex - Altera_Forum
Hi Alex
Thank you for responding, Yes, data are registered in the I/O cell. I'have checked, all connections are ok. Below the corresponding sdc file lines and attached the sd specification, could you check if it is correct? #create 50 mhz clockcreate_clock -period 20 -name {c0_sd_clk} [get_ports {c0_sd_clk}]
# constraint of sd output delay time (fpga input)
set_input_delay -clock { c0_sd_clk } -add_delay 14 [get_ports {c0_sd_dat* c0_sd_cmd}]
# constraint of sd output hold time (fpga input)
set_input_delay -clock c0_sd_clk -min -rise 2.5 [get_ports c0_sd_dat* c0_sd_cmd]
# constraint of sd input setup time (fpga output)
set_output_delay -clock c0_sd_clk -max -rise 6 [get_ports c0_sd_dat* c0_sd_cmd]
# constraint of sd input hold time (fpga output)
set_output_delay -clock c0_sd_clk -min -rise 2 [get_ports c0_sd_dat* c0_sd_cmd] Regards, Hery
Are you still having problems with this?
I don't see anything wrong with the set of constraints you've posted. Can I assume you used this same set of constraints successfully in your non-Nios version? My suspicion her is still with a higher level functional issue. Regards, Alex - Altera_Forum
Hi Alex,
Thanks for your help. Timing constraints and data synchronisations were failed. Regards, Hery
