12 years agoMulti SD CARD controller
Hi all, I'm doing a design with 4 SD cards, in sd 4 bits mode at 50MHz in parallel with an embedded Nios on a ARRIA V target. Here are the facts: - By instantiating the sd ip without Nio...
12 years agoAre you still having problems with this?
I don't see anything wrong with the set of constraints you've posted. Can I assume you used this same set of constraints successfully in your non-Nios version? My suspicion her is still with a higher level functional issue. Regards, Alex
