12 years agoMulti SD CARD controller
Hi all, I'm doing a design with 4 SD cards, in sd 4 bits mode at 50MHz in parallel with an embedded Nios on a ARRIA V target. Here are the facts: - By instantiating the sd ip without Nio...
12 years agoHow have you constrained this?
Yes, you will have to ensure you clock to out times are appropriate. However, you mention running at 50MHz - I don' think you should have much of a problem in Arria running at that frequency. Are you registering data on and off the FPGA in the I/O cell? Are you happy that, in connecting up your Nios core, you haven't inadvertently incorrectly connected something? Regards, Alex
