17 years agomodelsim vsim-3601 on counter
Hi folks- The following code returns in modelsim a # ** Error: (vsim-3601) Iteration limit reached at time 0 ps. when I run the simulation. However, when I step through the program, I se...
17 years agoI saved your code in a file counter.vhd, adding the correct library calls. I then created this test bench, saved as countertb.vhd:
library ieee;
use ieee.std_logic_1164.all;
entity TestBench is
end entity;
architecture bench of TestBench is
component bcdcounter
port (
clk : in std_logic;
reset : in std_logic;
count : out std_logic_vector(3 downto 0);
fullcount : out std_logic
end component;
signal clk : std_logic;
signal reset : std_logic;
signal count : std_logic_vector(3 downto 0);
signal fullcount : std_logic;
signal stoptest : std_logic;
begin
UUT : bcdcounter port map (clk,reset,count,fullcount);
ClkGen : process
begin
while stoptest /= '1' loop
clk <= '1';
wait for 5 ns;
clk <= '0';
wait for 5 ns;
end loop;
wait;
end process;
SigGen : process
begin
reset <= '1';
wait for 25 ns;
reset <= '0';
wait until fullcount = '1';
wait for 100 ns;
stoptest <= '1';
wait;
end process;
end architecture;
And used this compile script in Modelsim:vlib lib
vmap work lib
vcom -O0 counter.vhd
vcom -O0 countertb.vhd
vsim -novopt TestBench
add wave /*
run -all
wave zoomfullAnd it runs fine. So the problem doesn't come from your code.
