15 years agominimum time for IO pin to damage
hello all, there is a question about the minimum time for an IO pin of the FPGA like the cyclone EP1C6Q240.. I want to know the min. time for the pin to damage when it is exposed to a vo...
15 years ago --- Quote Start --- is the only difference is the speed --- Quote End --- Yes, mostly. If your application uses only slow logic, the ESD diodes should be fine. I don't see a particular problem with negative ESD transients, because they are absorbed by the substrate clamp diodes. According to the datasheet, you can expect 10 to 20V spikes for positive and negative standard 1 kV ESD pulses behind the protection device. That's a considerable reduction, but of course, Altera won't guarantee 100% safe operation for the FPGA. At least a two level protection would be needed to keep the maximum ratings strictly. You already said, that there's no room for it.
