ericmtzr
3 years agoMigrating Intel PSG Cyclone V GX to Agelix F
My customer is Migrating Intel PSG Cyclone V GX to Agelix F and running into the following compilation error: Error: Design cannot be programmed onto available F-Tiles because given location c...
sstrell
3 years agoAn IP in the design may have its own location constraints that prevent placement in the different device. You usually have to regenerate the IP so it can use the appropriate device resources. I doubt you can directly bring Cyclone V PCIe directly into an Agilex device. You'd have to recreate the IP using the IP designed for this device.
