MegaWizard Plug-In Manager : ALTPLL [Corrupted in Quartus Prime Lite 25.1]
yes, but known bug. Reported since several weeks in the forum.
Regards Frank
- Nitram8 months ago
Due to this is bug is present in PLL IP, which is used in nearly every design - it would be great to have available patch for it to not let wait the users for next release of Quartus Prime Lite/Standard editions. The releases of Quartus Prime Lite/Standard in past usually comes in autumn, which is quite long time.
- msx680x010 months ago
Thank you for your reply, and I apologise for repeating myself. I couldn't find it in the forum.
Kind regards.
- AqidAyman_Altera9 months ago
The workaround can be found in the link provided by RichardT_altera
I wanted to inform that this issue is still under investigation.
May I know if you have tried the workaround and see if it works on your side?
Aqid- msx680x09 months ago
Hi. I haven't tried the workaround, and I've also noticed that sometimes an error appears that prevents the wizard from opening. Whereas in the previous Quartus Prime Lite 24.1, it works fine.
Kind regards.
- FvM9 months ago
no reason to apologize. Just wanted to inform that there's a previous discussion with solutions. Forum search isn't very purposeful yet. I e.g. didn't find out how to perform an explicite and conjunction of terms, can be my fault.
Regards Frank
