Maxplus + Byteblaster not available
HI Frank,
it would be fine, if you could try this. I tried the setup on four notebooks with parallel ports: One Lenovo one IBM, one Fujitsu Siemens and one Roda.
Parallel Port config: I tried ECP, EPP, Standard bidirectional, Starting Addressses 0x278, 0x378, 3BC … Allways the same error on all notebooks.
Maybe it helps you when I thell you my configs:
All notebooks are Windows XP 32 and have a parallel port (RAM is between 2GB and 4GB).
From the orig CD:
First: I selected programer only
Second: I selected Full/Flexlm/… installieren
Then I told Windows that I have a Byteblaster:
Control Panel – Hardware – add new Hardware – is connected – Audio/Video/Gamingcontroller – Have disk – c:\maxplus2\drivers\win200
In MaxPlus+ I do the following:
File – open – the GDF-File
File – Project – set Project to current file
(Maybe File – Hirarchy Top before).
Maxplus2 – Compiler – Start – when ready:
Maxplus2 – Programmer
File – Select Programing File – (Select the pof file because the sof file doesn’t work).
And now back tot he programmer dialog. Select program on the left side – that’s I always did before, but now the program button on the left is grayed out becaulse of no hardware selected. And when I click on Options – Hardware setup – I can’t select byteblaster.
I have one colleague with one working notebook for this, but he is 2 car hours away.
He came to me and could connect to my programmer, select Byteblaster II and updated a program on my processor.
But 2 hours driving (one direction) is a long way and he also doesn’t have an idea what I did wrong.
The parallel port mode of my colleague is ECP, but I think on my old lenovo notebook I just had standard and selected the starting address of 0x278 or 0x378 – and this also worked well.
If you need anything from me, or I should try something, please tell me.
It would be very nice from you, if you could help me.
Thank you so much!
Andreas
HI!
do you have any news for me?
regards,
Andreas
