MAXII to MAX5 CPLD foot print compatability
- 2 years ago
It's all described in device handbook and datasheet.GPIO have weak pull-up resistors to respective VCCIO until user mode becomes active. State of unused pins can be globally selected in Quartus device and pin options.
"Reserves all unused pins on the target device in one of 5 states: as inputs that are tri-stated, as outputs that drive ground, as outputs that drive an unspecified signal, as input tri-stated with bus-hold, or as input tri-stated with weak pull-up."
Personally, I won't choose high-Z without pull-up if there are any unconnected GPIO pins because floating inputs can involve additional device current consumption.
Frank
Nazrul Naim
- KrishnamRaju2 years ago
Dear Naim
Please help us on below poits,
1. Before programming the CPLD MAX V, What are the default states of all I/Os.
Initiall after power up all I/Os(Before programming the CPLD) are driving some logic to processor beacuse of which I am facing some issue.
2. I want to keep all un used pins as input with high impoedence after programming the CPLD. How to make this setting in Quartus tool.
With Regards
Krishnam Raju M
