MAXII to MAX5 CPLD foot print compatability
- 2 years ago
It's all described in device handbook and datasheet.GPIO have weak pull-up resistors to respective VCCIO until user mode becomes active. State of unused pins can be globally selected in Quartus device and pin options.
"Reserves all unused pins on the target device in one of 5 states: as inputs that are tri-stated, as outputs that drive ground, as outputs that drive an unspecified signal, as input tri-stated with bus-hold, or as input tri-stated with weak pull-up."
Personally, I won't choose high-Z without pull-up if there are any unconnected GPIO pins because floating inputs can involve additional device current consumption.
Frank
@KrishnamRaju wrote:I found only T6 as the difference which was used as GPIO in my design. This GPIO is not crucial for my design. Can I gohead with testing?
good if you can get along without usingT6 as GPIO. Preferably you'll connect the pin to ground, but I guess MAX V will work even if you leave it floating.
Frank
