MAXII to MAX5 CPLD foot print compatability
- 2 years ago
It's all described in device handbook and datasheet.GPIO have weak pull-up resistors to respective VCCIO until user mode becomes active. State of unused pins can be globally selected in Quartus device and pin options.
"Reserves all unused pins on the target device in one of 5 states: as inputs that are tri-stated, as outputs that drive ground, as outputs that drive an unspecified signal, as input tri-stated with bus-hold, or as input tri-stated with weak pull-up."
Personally, I won't choose high-Z without pull-up if there are any unconnected GPIO pins because floating inputs can involve additional device current consumption.
Frank
Sorry for the delay. As user 'FvM' have replied. The reply can be accepted which is the devices are pin compatibility and need to check the signal assignments by importing the MAX II pin assignments to MAX V design. Do let me know if I can assist you further.
Nazrul Naim
- KrishnamRaju2 years ago
Dear Naim
I found a T6 pin which is ground in MAX V is I/O in MAX II.
Can you please look at this and the reason for this difference.
With Regards
Krishnam Raju M
