16 years agoMAX7000 initialization problem
I am using Quartus II with a MAX7000s EPM7128. I am having a problem with an 8 bit latch not being initialized properly on power up of the CPLD. The latch outputs should be all zero after the cpl...
16 years agotry (and it is just a guess) several inverters to delay and invert a signal S to S_inverted.(you may need the keep attribute or get quartus to insert delay instead). Then detect edge transition:
reset <= S and not S_inverted or not S and S_inverted;
