16 years agoMAX7000 initialization problem
I am using Quartus II with a MAX7000s EPM7128. I am having a problem with an 8 bit latch not being initialized properly on power up of the CPLD. The latch outputs should be all zero after the cpl...
16 years agoI thought we are talking about clked registers(though called latches). I understand you have clk and therefore you can run a counter at powerup reseting until count 6 and release reset at count 7.
Without clk, I never tried that but I can imagine a non standard method of a signal followed by good delay then use logic for edge detection. After all, power up values are insignificant if you have your own external or internal reset.
