16 years agoMAX7000 initialization problem
I am using Quartus II with a MAX7000s EPM7128. I am having a problem with an 8 bit latch not being initialized properly on power up of the CPLD. The latch outputs should be all zero after the cpl...
16 years agoIt could be the external input is floating...touch it by hand and see...
power-up state is a common problem if you depend on device's reset release after configuration. It is unreliable as vendors admit. To overcome that, I normally add my own powerup internal reset using say a counter that counts up from zero and stops at say 7 and for ever. This method needs a battle with optimisation and raises the question of how to get counter start at zero. Well, if you set powerup don't care to disabled you have high chance of success.
