Mahmoud353
1 year agoMax10M-16-SA-U-169 program without having the project file
Hi, I am trying to program the already designed and programmed Intel Max 10M-16-SA-U-169 to change the states of some of the components connecting to the FPGA. I do not have the project file and the...
FvM
11 months agoHi, boundary scan logic allows also to change data direction (enable/disable tri-state drivers) and set output state of pins. You can e.g. read or write memory devices connected to FPGA pins. There are various BSDL tools available, I'm e.g. using TopJTAG Probe with USB-Blaster and Altera FPGA.
