9 years agoMAX10/DE10-Lite board : SDRAM(64MB) problem downloading elf-file
Hi All,
I am using the DE10-Lite board with Quartus version 16.1. My application is running without any problems on a DE1 board (8MB SDRAM), on a DE0-Nano board(16MB SDRAM) and on a BeMicro CV board which is no longer available, so I decided to use the DE10-Lite board. I have created a minimal configuration to narrow the problem. Enclosed, please find the Qsys file. If necessary, I can provide the whole project as zip-file. The program is running without any problems if only the onchip_memory is used, see 1). The problem occurs if using the SDRAM only. ****************************************************************** 1) ok, using onchip_memory Downloading 01000000 ( 0%) Downloading 01010628 (95%) Downloaded 66KB in 1.1s (60.0KB/s) Verifying 01000000 ( 0%) Verifying 01010628 (95%) Verified OK Starting processor at address 0x01000230 ***************************************************************** 2) ERROR , using SDRAM Downloading 04000000 ( 0%) Downloading 040105B4 (95%) Downloaded 66KB in 1.1s (60.0KB/s) Verifying 04000000 ( 0%) Verify failed between address 0x4000000 and 0x400FA63 Leaving target processor paused ****************************************************************** I already tried different possibilities to solve the problem and followed also the hints and examples in the DE10-Lite_v.2.0.0_SystemCD but without success. I also tried to use the Nios II (Classic) -E Processor with external PLL : same problem. I am using the Single Uncompressed Image (3584Kbits UFM) Device option. At the moment, I am only able to start the program from the onchip_memory, so I tried to get access to my data which is based on a 48 MB union by changing via NiosII-BSP Editor the mapping from the .rwdata to the SDRAM. Unfortunately I have no experience how to do that correctly and I did run in a lot of other problems, probably my fault. It would be nice if someone can help me. In general, however, it only makes sense if the SDRAM is working correctly and I suspect that the problem is based in the RESET timing ? Every reference is welcome. Many thanks in advance, Reinhard1 Reply
In the meantime, I have solved the problem by myself.
It was related to the PINs DRAM_UDQM and DRAM_LDQM. These pins have always been incorrectly created / designated (in version Quartus 16.1) in a Qsys "Generate HDL ..." I changed it as follows: # DRAM_LDQM,Unknown,PIN_V22,5,B5_N0,3.3-V LVTTL,,4ma,,, # DRAM_UDQM,Unknown,PIN_J21,6,B6_N0,3.3-V LVTTL,,4ma,,, DRAM_dqm[1],Unknown,PIN_V22,5,B5_N0,3.3-V LVTTL,,4ma,,, DRAM_dqm[0],Unknown,PIN_J21,6,B6_N0,3.3-V LVTTL,,4ma,,,
