Johny123's avatar
Johny123
3 years ago
MAX10 webserver / socket server working sample
Is there a sample working design available on MAX10 development kit, for a simple socket server or webserver/remote-update with Quartus versions > 17.0. All current designs available in the design store do not pass the Qsys generation stage without error.
  • KellyJialin_Goh's avatar
    KellyJialin_Goh
    As we do not receive any response from you on the previous reply that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    Thank you.
    Kelly Jialin, GOH
    KellyJialin_Goh
    Any updates from your side on the example design that I provided?
    Regards.
    Kelly
    KellyJialin_Goh
    Regards.
    Kelly
    KellyJialin_Goh
    Yes, the design example is compatible on the 16.0 Quartus version and I am glad you found your workaround.
    The only latest design example that can be compiled on Quartus would be the 17.1.1 version which is available here for you to choose, I will put it here again for your reference: https://www.intel.com/content/www/us/en/design-example/714915/max-10-nios-ii-simple-socket-server-ethernet-example.html
    Hope this clarifies your doubts.
    Thank you.
    Kelly
  • Johny123's avatar
    Johny123
    Hi Kelly,
    Yes, thanks for confirming. We surmised as much from our search and the design built fine on an older Windows 7 system.
    We had subsequent issues with the NIOS eclipse build flow on >17.0, though. The TSE mac drivers seem to have been upgraded to use msgdma while the design example has sgdma. It built successfully on older 16.0 (deprecated now?!). So for the time being, we have worked around this issue by copying the older 16.0 bsp drivers to replace the current drivers on >17.0 quartus. Just wanted to confirm if this is the same at your end as well; and if there is an example design available which will be compatible with the latest quartus versions i.e. with msgdma ?
    KellyJialin_Goh
    Apologies for the late reply but I have got news from the engineering team where Quartus is not yet supported on Windows 11, therefore the design example that you are compiling will have errors.
    Hope this clarifies your doubts. Thank you.
    Kelly
  • Johny123's avatar
    Johny123
    Hi Farabi,
    Thanks for the quick revert.
    Yes, I tried the ,
  • Farabi_Altera's avatar
    Farabi_Altera
    May I know which design(socket server) you referring to? Do you have the link?
    regards,
    Farabi
