Johny123
3 years agoMAX10 webserver / socket server working sample
Is there a sample working design available on MAX10 development kit, for a simple socket server or webserver/remote-update with Quartus versions > 17.0. All current designs available in the de...
Johny123
3 years agoHi Kelly,
Yes, thanks for confirming. We surmised as much from our search and the design built fine on an older Windows 7 system.
We had subsequent issues with the NIOS eclipse build flow on >17.0, though. The TSE mac drivers seem to have been upgraded to use msgdma while the design example has sgdma. It built successfully on older 16.0 (deprecated now?!). So for the time being, we have worked around this issue by copying the older 16.0 bsp drivers to replace the current drivers on >17.0 quartus. Just wanted to confirm if this is the same at your end as well; and if there is an example design available which will be compatible with the latest quartus versions i.e. with msgdma ?
