SAB4887's avatar
SAB4887
4 years ago
MAX10 UART RSU EXAMPLE NOT WORKING
Hello ,
I have MAX10 development kit. I am trying to play with MAX10 RSU with UART NIOS example files according to AN741 document.
I am able to program all files correctly but when i connect UART to terminal i don't see any compunction there.
Any idea what i am missing ???
    • braind1's avatar
      braind1
      This is a private video. Can you make it public?
  • SAB4887's avatar
    SAB4887
    I did follow that video but still i am seeing same result.
  • SAB4887's avatar
    SAB4887
    Did i miss any, above explain steps i am following ?
    • hareesh's avatar
      hareesh
      We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
      Thank you.
    • SAB4887's avatar
      SAB4887
      Sorry for late reply.
      I did try that example project from above link. But still i am seeing same issue.
  • braind1's avatar
    braind1
    I have the same problem. Followed the same steps as SAB4887, except that I am using a Pu tty UART terminal. Should work the same, as its just UART. The 'Remote Terminal.exe' appears unable to run on my Linux machine. I do see the USB device appear under my /dev folder, so I am confident the connection from my MAX10 dev board is there.
    Intel support, can you update this thread?
    • braind1's avatar
      braind1
      Note, I am using the Master reference files. I was able to program all into the device.
      • braind1's avatar
        braind1
        The UART status LEDs (D13, D14) do not light up when I attempt to transmit from my host computer.
  • braind1's avatar
    braind1
    @Ash_R_Intel can you or another Intel representative provide me with support on this topic? I am still blocked by Nios II not displaying output over UART. It seems like its not booting at all.
