SAB4887
4 years agoMAX10 UART RSU EXAMPLE NOT WORKING
Hello ,
I have MAX10 development kit. I am trying to play with MAX10 RSU with UART NIOS example files according to AN741 document.
I am able to program all files correctly but when i connect UA...
braind1
2 years agoI have the same problem. Followed the same steps as SAB4887, except that I am using a Pu tty UART terminal. Should work the same, as its just UART. The 'Remote Terminal.exe' appears unable to run on my Linux machine. I do see the USB device appear under my /dev folder, so I am confident the connection from my MAX10 dev board is there.
Intel support, can you update this thread?
- braind12 years ago
Note, I am using the Master reference files. I was able to program all into the device.
