MAX10 Soft SERDES set_input_delay constraints
- 6 months ago
Does the Recovery violation mean the PLL reset is failing timing?
Yes — but only because it might have been constrained incorrectly.
Is i_rst_l an asynchronous reset?
Asynchronous resets are not clocked inputs and must not be constrained using set_input_delay. Applying input delay constraints to an async reset causes the timing analyzer to treat the reset as if it were data, which might lead to Recovery or Removal timing violations.
This is what I am suspecting to be the cause.
Additionally, you should use a virtual clock for source‑synchronous interface constraints.
Checkout the AN 433: Constraining and Analyzing Source-Synchronous Interfaces
https://cdrdv2-public.intel.com/653688/an433.pdf
You may checkout this user guide on how to Applying Input Delay Constraint for LVDS SERDES Receiver
https://docs.altera.com/r/docs/683760/24.1/max-10-high-speed-lvds-i/o-user-guide/initializing-the-soft-lvds-ip-core?tocId=qCaxGpfsxdGb1RUBaR9ShQ
Richard Tan
Richard Tan
Thanks Richard, that answered the question and by constraining the interface using a virtual clock as called out for source synchronous DDR interfaces in AN433 I was able to get a more realistic timing report. The reset was constrained and I removed that. I also lowered my data and clock rate from 720 to 640Mbps because I found that because the phase adjustment has a step size of 45 degrees at 720MHz, the phase couldn't be set to get a reasonable setup time. At 640MHz the step size is 22.5 degrees and by setting the phase to 90 degrees and iteratively adjusting the input delay parameter on the IO I was able to maximize the setup time.
Again, thank you for your help.
Sean
