Max10 Programming with daul boot image
- 3 years ago
Please be advised that due to the absence of a response from you regarding the previous notification we provided, we will be transitioning this thread to community support. If you have any new questions or concerns, we kindly suggest opening a new thread to receive assistance from Intel experts. However, if you do not have any further inquiries, the community users will be available to assist you on this thread. Thank you for your understanding.
you definitely should review the above mentioned configuration user guide. It clarifies about flash memory utilisation in dual boot configuration. CFM1 in Quartus Programmer stands for CFM1 + CFM2.
Page0/CFM0 is usually the factory image in a RSU configuration, Page1/CFM1 the application image.
Frank
Dear Frank
Thanks for your reply.
Yes, I've study the configuration user guide already.
According to Onchip flash IP setting on my design to compare the table you post and also the user guilde's change list the Image 2 should stands for CFM1 and Image1 should stands for CFM0 , right ?
Here is the question , if I only select CFM0 under Program/Configure in programming tool. It should be programmed image0(Page0) into the Flash.
While I earsed the CFM0 by programming tool it should not have any logic implement in next AC power on.
But result shows Image1(Page1) instead.
It was confused me that is only Image1( Page1) 's sof exist in CFM1 ?
P.S. I've eraserd CFM0/CFM1/UFM before programming CFM0 only .
Thanks!
Evan.
