MAX10 programming problem
Hello! I am trying to program my max10 device
I tried to program with .sof through Quartus programmer 18 and it went well, both verilog and nios part worked.
But when I try .pof I got:
Info (209060): Started Programmer operation at Tue Oct 08 15:19:14 2019
Info (209017): Device 1 contains JTAG ID code 0x031830DD
Info (209060): Started Programmer operation at Tue Oct 08 15:19:16 2019
Info (209016): Configuring device index 1
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Tue Oct 08 15:19:17 2019
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Oct 08 15:19:23 2019I tried creating .pof with "Converting programming files" and the result was the same. Is there any suggestion to this problem?
- Ahmed_H_Intel1
Here are some examples:
https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/dual-boot-design-example-max10-de10-lite/
https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/max10-remote-system-upgrade-rsu-over-uart-for-nios-ii-processor/
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/sdram-nios-test-max10-de10-lite/
- Ahmed_H_Intel1
There are many things may cause this issue, Can you please check if you are choosing the correct Flash device and the boot settings?
Which board you are using? I recommend you try to download one of the examples below and see the difference between what you are doing and what inside these examples. Or I offer you to create a simple NIOS design (Hellw World) on one of the MAX 10 Dev-kits.
- DZabr
Unfortunately, I have no Dev-kit boards, it is my own device. I checked forum and found a man https://forums.intel.com/s/question/0D50P00004K8maLSAR/quartus18x191-issue1-programmer that had successful programming with programmer version 15. We tried, and it works! But still no luck with version 16 and 18. Well, at least it works there.
