9 years agoMAX10 Programmable IOE Delay
According to the datasheet, MAX10 have Programmable IOE Delay. How can I use it? Through which IP? Through which Assignment? Through SDC constraint? Best regards,3 Replies
Dynamic delay chains are only available in certain device families, typically Cyclone V, Stratix V, Aria V and newer. It's not available in MAX 10.
Cheers, Alex - Altera_Forum
Thank you for the information.
This cover the static delay assignment case but I need dynamic (real time) update of the IOE delay. I know that Cyclone and others uses ALTIOBUF IP but this is not available on MAX 10. Any idea? - Altera_Forum
See: "how do i set the ioe programmable delay values as listed in the device datasheet in the quartus ii software? (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05052011_592.html)".
Cheers, Alex
