avib
6 years agoMAX10 Power Supplies Recommended Operating Conditions
We are using the MAX10 device in one of our designs. We found out during worse case analysis that our power supplies design could theoretically reach slightly above the recommended operating co...
JonWay_altera
6 years agoHi @avib
The device performance are only validated using the recommended supply voltage range specified in the datasheet. Without data, we are not able to tell what will/will not happen if you use outside of the recommended range.
- avib6 years ago
Thank you
