max10 pin assignment question
- 1 year ago
Thank you, FvM, for the answer. To add on:
1) The default I/O standard for pins is device-specific. To change the default I/O standard:i) Click Assignments > Device.
ii) On the Device dialog box, click Device and Pin Options.
iii) In the Category list, select Voltage and then select the desired I/O standard.2) You should see as below:
Richard Tan
Yes, you are right, change the the default setting to assignment works fine.
still have two questions:
1) why bank 1, 4, 7 VCCIO is 2.5V. It should target 3.3V single supply.
2) I don't see this path, you can see my screen shot below.
Compilation Report\Fitter\Resource Section\I/O Standards Section\I/O Assigment Warnings
Richard Tan
