10 years ago
MAX10 FPGA versus Cyclone V
I wrote some VHDL code for the Cyclone V FPGA with ALTLVDS_RX function.
Can I use the same code for the MAX10 FPGA?
Regards.
    You can also check in the ALTLVDS_RX user guide to see if there is any device family support list.
    --- Quote Start ---
    Why don't you try it?
    --- Quote End ---
    yeah.... just change the device selection and spend a little bit of time to see what is the compilation result.
    If not mistaken, the Max10 support LVDS using soft logic serdes. I think the same CV ALTLVDS_RX might not work if you compile directly. But you could give it a try also. If not working, then try re-instantiate the IPs.
