10 years agoMAX10 FPGA versus Cyclone V
Hi, I wrote some VHDL code for the Cyclone V FPGA with ALTLVDS_RX function. Can I use the same code for the MAX10 FPGA? Regards.
10 years agoIf not mistaken, the Max10 support LVDS using soft logic serdes. I think the same CV ALTLVDS_RX might not work if you compile directly. But you could give it a try also. If not working, then try re-instantiate the IPs.
