11 years agoMAX10 FPGA SPI Flash Configure?
Could I use external SPI flash (EPCQ) to fo configure MAX10 FPGA each time when the FPGA powers up?
I can't find the special pins for external SPI flash (EPCQ) to configure MAX10 FPGA.3 Replies
--- Quote Start --- MAX10 FPGA can only use internal flash to configure each time when the FPGA powers up, right? --- Quote End --- Right. All but the smallest device have the capability of storing two different configurations that can be selected based on a pin. Do you have a need for more than two config options? - Altera_Forum
Yes, what I mean is the same as http://www.alteraforum.com/forum/showthread.php?t=49491 ?
MAX10 FPGA can only use internal flash to configure each time when the FPGA powers up, right? - Altera_Forum
Is this the same as http://www.alteraforum.com/forum/showthread.php?t=49491 ?
Is your goal to have more than two configurations to choose from? If so maybe use a small Cyclone instead?
