THAUS1
4 years agoMAX10 EPE M9K Fmax limit?
I try to use EPE on MAX10. I generate accuTrack_early_pwr.csv file.
My design have some dual port block ram running at 320MHz:
BLOCK,M9K,count,1,ram_mode,"Simple Dual Port",ram_read_during_...
SyafieqS
4 years agoNoted. If that's so, since this case has been idling, I would put this to close pending and suggest you to create a new case mentining this case for follow up in future. In the meantime you may change the frequency as documented to avoid any further issue. Let me know any concern on this.
