MAX10 embedded memory contents after reconfiguration
Hello.
I will use embedded memory as "RAM:1-PORT" or "RAM:2-PORT" on MAX10 device.
If I reconfigure MAX10 device using same configuration data under correct supplying power,can that memory hold the data contents before reconfiguration in after of reconfiguration?
Thank you.
- SyafieqS
Hi Kei,
There is no information for this in doc. Have you test it at your end what is the behavior of it?
- Ky8
Hello SyafieqS_Intel,
I only had a question but I did not test it.
Thank you for telling me that there is no information for this in doc.
I understood using like so was not guaranteed.
Because device manufacturer does not guarantee it, I do not intend to use the function even if such a behavior is observed.Thank you very much for your kind reply.
- NurAiman_M_Intel
This is to let you know that I am currently checking this with my internal team. I will get back to you once I have the findings.
Aiman
- Ky8
Hello Aiman,
Thank you very much.
I understood.
If you get the findings, please let me know.
Thank you.
Ky8
