Ky8
5 years agoMAX10 embedded memory contents after reconfiguration
Hello.
I will use embedded memory as "RAM:1-PORT" or "RAM:2-PORT" on MAX10 device.
If I reconfigure MAX10 device using same configuration data under correct supplying power,can that memory hold t...
SyafieqS
5 years agoHi Kei,
There is no information for this in doc. Have you test it at your end what is the behavior of it?
- Ky85 years ago
Hello SyafieqS_Intel,
I only had a question but I did not test it.
Thank you for telling me that there is no information for this in doc.
I understood using like so was not guaranteed.
Because device manufacturer does not guarantee it, I do not intend to use the function even if such a behavior is observed.Thank you very much for your kind reply.
