Ky8
5 years agoMAX10 embedded memory contents after reconfiguration
Hello.
I will use embedded memory as "RAM:1-PORT" or "RAM:2-PORT" on MAX10 device.
If I reconfigure MAX10 device using same configuration data under correct supplying power,can that memory hold t...
NurAiman_M_Intel
5 years agoHi,
This is to let you know that I am currently checking this with my internal team. I will get back to you once I have the findings.
Aiman
Ky8
5 years agoHello Aiman,
Thank you very much.
I understood.
If you get the findings, please let me know.
Thank you.
Ky8
