MAX10 DDR3 Timing
Hi Adzim,
When switching the FPGA from 10M16DAF484 to 10M08DAF484 in the DDR3 memory controller example design generated from the design, a fitter error occurs
Error (16076): This specific device does not support listening to nsleep port. Parameter "listen_to_nsleep_signal" of atom "ddr3_mem_ctrl_example_if0:if0|ddr3_mem_ctrl_example_if0_p0:p0|ddr3_mem_ctrl_example_if0_p0_memphy_m10:umemphy|ddr3_mem_ctrl_example_if0_p0_dqdqs_pads_m10:dq_ddio[1].ubidir_dq_dqs|altera_gpio_lite:dqs_ddio_io|altgpio_one_bit:gpio_one_bit.i_loop[0].altgpio_bit_i|diff_input_buf.diff_input_buf_with_nsleep.ibuf" must be set to FALSE.
Error (12582): Input port PHYMEMCLOCK of "ddr3_mem_ctrl_example_if0:if0|ddr3_mem_ctrl_example_if0_p0:p0|ddr3_mem_ctrl_example_if0_p0_memphy_m10:umemphy|ddr3_mem_ctrl_example_if0_p0_addr_cmd_pads_m10:uaddr_cmd_pads|addr_cmd_pad_m10:address_gen[0].uaddress_pad|altera_gpio_lite:uadc_pad|altgpio_one_bit:gpio_one_bit.i_loop[0].altgpio_bit_i|out_path_enhanced_ddr.fr_out_data_ddio" must not be connected.
Error (12584): This specific device does not support the enhanced DDR HIO. Parameter "use_enhanced_ddr_hio" of atom "ddr3_mem_ctrl_example_if0:if0|ddr3_mem_ctrl_example_if0_p0:p0|ddr3_mem_ctrl_example_if0_p0_memphy_m10:umemphy|ddr3_mem_ctrl_example_if0_p0_addr_cmd_pads_m10:uaddr_cmd_pads|addr_cmd_pad_m10:address_gen[0].uaddress_pad|altera_gpio_lite:uadc_pad|altgpio_one_bit:gpio_one_bit.i_loop[0].altgpio_bit_i|out_path_enhanced_ddr.fr_out_data_ddio" must be set to FALSE.
Error (171113): The design contains 16 blocks of type "Double data rate I/O input circuitry" but the selected device 10M08DAF484C8G does not support such blocks
If I change the device to 10M16DAF484I6G and run the ddr3_mem_ctrl_example_if0_p0_pin_assignments.tcl, I achieve the same timing values concerning mem_dqs[*]. The timing issue related to clk[4]_afi_clk does not appear in our normal design.
Thus, we also have the same problems in the example design.
Hi Korbinian,
For those nsleep error, you need to make sure that the device is 10M16DAF484I6G or support device with DDR3.
Try to add this timing contraint into your sdc file because the reset synchroinzer may cause timing violation
set_false_path -from altera_reset_controller:rst_controller*|altera_reset_synchronizer:alt_rst_sync_uq1|altera_reset_synchronizer_int_chain_out -to *:if0|*:p0|*_memphy_m10:umemphy|*_reset_m10:ureset|*_reset_sync:*|reset_reg[*]
And also set the Compiler setting to Performance:
And Optimization Technique to Speed in Advanced Settings (Synthesis):
