kw_arrow
7 months agoMAX10 DDR3 Timing
Hi, I need a definitive statement regarding the timing. The two attached screenshots were created with Quartus 23.1 but can also be found in 25.1. Although adjusting the temperature range reduced t...
AdzimZM_Altera
6 months agoHi Korbinian,
Thanks for the update.
In this case, can you generate an example design from the DDR3 EMIF IP Editor(from current design) and compile the design?
If it an IP setting issue, we might be able see the similar timing in the example design.
Adzim
