Max10 CRAM configuration with RPD file via system console/host CPU
MAX 10 FPGA does support Remote System Upgrade feature. You may like to refer to the following document on options available to do this.
It also provide links to a RSU example. It is also possible to access RSU block through user logic, which in your case will be based on SPI interface (link provided in above document).
Please note that CFM/UFM requires a .pof file.
Hello Ash,
I wonder if you can help me. My goal is to implement RSU on a max 10 device via the easiest method.
My FPGA design is is all discreet logic, manually written in VHDL, I have no Nios implementation and have no experience with Nios.
Until now, I have created my design in Quartus 18.1 using only manually written VHDL, and programmed a pof to the device each time via usb blaster.
Could you recommend an approach for somebody like me, and any examples that might help?
Kind regards
AT
